1 - 5 of 5 Posts
Finally got a chance to get my fork seals replace today. The right one was leaking, but I had both replaced. Turns out that the spring on the upper part of the seal came off. The seals have a spring on both sides of the seal to keep pressure on the tube. Just something you might want to check if you are having an issue. Plus I had my mechanic do the 7500 mi service while it was in the shop.
:+1: Hey my right shock has been slightly leaking for a couple of weeks now too! I thought i caused it from the tie wrap for suspension adjustment.Does seal replacement look like something tough for the average joe to do? Expensive?
1 - 5 of 5 Posts
