Incorrect? BS. Revalving the suspensionMy tuner says ALL zx10r have incorrect rebound valving and to back out both screws ALL THE WAY..or get a revalve kit(bigger holes)
:iamwithstYes, there is nut that locks against the fork cap. After removing the caps, adjust the nuts to the correct distance before reinstalling the caps.
The stock adjusters are not near as good as aftermarket, but they do work and should be used (not just turned all the way out.) True, many use too much rebound.
No, you can not modifiy travel by adjusting oil level.
i thank all for the info , i understand that i cant get more travel then was manufactured into the forks . the manual says there is 120mm of usable travel and i am only using 80mm do these numbers sound right? edgeflyer could be right that the forks were taken apart and incorrecty reassembled , im thinking they might have put more oil then recomended in them and improperly instaled the fork caps. and i put a tie strap on the fork leg and did a test stop from 140mph on a road with a incline and used 60mm of travel
