1 - 4 of 4 Posts
hi guys just a quick question and wondering whats the oil capacity per leg.
been told 490ml or 590ml just unsure which is right
thanks
download a manual from this site.
capacity depends on how much of the fork you are disassembling ( i.e. - changing oil vs changing seals would call for different amounts of oil)
Does not drive into smoke
From the manual:
Amount per side:
  • When changing oil: approx. 490mL
  • After disassembly and completely dry: 576 +/- 4mL
In any case, measure the oil level as the distance from the oil surface to the top of the tube: should be 91mm (+/- 2mm).
1 - 4 of 4 Posts
