1 - 15 of 15 Posts
Service manual specifies "molybdenum disulfide oil solution" to lube head bolt threads and washers.
What is this? Assembly lube? The only stuff I found at parts stores is multi purpose bearing grease with moly. What is the right stuff and where to find? Could I just use motor oil?
Am I needlessly obsessing over minor details?
Most assembly lube has moly. Torque values will change with diff lubricants, it's worth doing correctly. I like Permatex assembly lube, use sparingly.
Discussion Starter · #4 ·
Thanks. I'll look for it!
ARP includes a moly lube with their fasteners if I'm not mistaken. You can buy the lube by itself, it could be worth looking into if all else fails.
hi lenshead,i take it your changing your sprocket?....mo:apply molybdenum disulfide oil solution,(mixture of engine oil and molybdenum disulfide grease in a weight ratio is 10:1....taken straight from kawasaki factory manual!hope this helps....ps 10 parts engine oil/1 part grease.
Discussion Starter · #8 ·
That's very helpful, where in the manual does it say that?
Discussion Starter · #9 · (Edited)
Oops! That stuff contains no moly. but Permatex. ®. Ultra Disc Brake Caliper Lube, Silicone/Moly does, so does Permatex Slik-Pak 5th Wheel Grease.
ARP is easy to find on-line, but I'll take a drive around to my local shops first.
Thanks for the info, guys!
Edit: this is what I ended up with. Moly disufide is a solid similar to graphite and does not tend to stay suspended in oil. So it is usually mixed with grease in a paste form. This seems to re-enforce the above service manual instruction about mixing with motor oil.
Same as what dsbat stated and there should also be numbers for a certain weight motor oil as well. Do no over lube and be very gentle if its a first gen as their case metal was a little soft.:thumbsup:
I actually bought the same stuff to prepare for shim removal on the valve. Everything was in Spec so never used it but I think I will keep it just encase. :wink:
bloo
hi lenshead,all i can say is the pdf manual is missing some text that kawasaki puts in the factory manual??i bought the proper manual from my kawasaki dealer (70 quid)and its in there.hear's a pic..
Discussion Starter · #15 · (Edited)
WOW. That info is not in my PDF. Rep for you my freind!:hello:
Makes me wonder what else is missing. I would have appreciated better instructions on alternator installation. It has a spring loaded gear with no easy way to pre-load it so it mates with the clutch gear....Grrrr....
1 - 15 of 15 Posts
