The bars that is......
did this on my gen3, way more comfortable :wink2:
I am wondering the same, I can't spot the difference right away in comparing the pics.Not trying to be stupid, but what did you do.
He flipped the clip ons, right on left/left on right. Raises the bars slightly to improve the riding position for street riding. You will notice the hole on the left handlebar clip on mount, that is for the bolt to lock the clip on to the triple tree when they were mounted factory.I am wondering the same, I can't spot the difference right away in comparing the pics.
Old joints typically. It's pushes your body upright slightly by flipping the clip on's.Not trying to be stupid, but what did you do. oem configuration is perfect for me so also want to know what is stressed to even want a change.
I understood what the OP did but wonder about the locating holes for switchgear, throttle, etcetera. Are they in the same place? Or redrill?Not trying to be stupid, but what did you do. oem configuration is perfect for me so also want to know what is stressed to even want a change.
I re-drilled. The problem I had was the bars hitting the upper fairing after the switch. I had to lower the clip ons down the fork tube a bit to keep it from hitting which negated the flip somewhat. Didnt like that the collar wasnt touching the triple clamp either so I added a spacer. But overall it felt better than the stock position even after all of that.I understood what the OP did but wonder about the locating holes for switchgear, throttle, etcetera. Are they in the same place? Or redrill?
Bar position perfect for me but I see how some would like a little more room. Tried the Helibars on GSX-R 750, hated them and went back to stock clip-ons.
Even a few millimeters makes a difference. Long as it's all secure.I re-drilled. The problem I had was the bars hitting the upper fairing after the switch. I had to lower the clip ons down the fork tube a bit to keep it from hitting which negated the flip somewhat. Didnt like that the collar wasnt touching the triple clamp either so I added a spacer. But overall it felt better than the stock position even after all of that.
