1 - 8 of 8 Posts
Well after 4 months of snow and having a broke zx10 I decided it was time to get her fixed. After two dead battery's I went ahead and replaced the voltage regulator/rectifier and threw a new battery in. Now I am charging at 14.5 and looking good. Before the new regulator I was only at 12v while the bike was on and eventually the battery just wouldn't work anymore.
Replacing the regulator was a bitch. First I spen't almost a hour just taking the two bolts off that hold the thing on. Then I couldn't get the electrical connection plugs off to save my life in the limited space I had. So I had to unbolt the whole subframe, exhaust, and tank so I could tilt everything up and get my hands in there. Now I have to put everything back togeather and that should be fun considering I don't know where half the bolts go.
Sounds like you will be havin fun make sure you post some pics :thumbsup:
Snake driver would have been ur friend! they make it look so easy in the manuel huh! i had a hell of a time with mine too but the snake took care of it quick!
I only have 6500~ miles and its a 06 zx10r. I don't really know what happened to it. The bike ran fine then I joined the Air Force and was gone for 10 months in training. When I came back the battery wouldn't hold a charge and I just thought it was a bad battery. So I baught a new battery and still had problems. While the bike was running if I turned the high beams on, the low beam would go out. Then while running the bike one day the main 30amp fuse blew. I replaced the fuse and the bike wouldn't hold a charge anymore. So after doing some research and talking to a guy back home who has done some work on my bike in the past I decided that the next step was the regulator. Things seem fine now, but time will tell. If this doesn't fix it, I guess alternator is next. I just hope its fixed now because my wife is pissed that I am spending so much money on the bike.
Quick question guys. I was putting everything back togeather and I kinda lost a socket. I can't see it for the life of me, and I'm pretty sure it fill into the swingarm. Just behind the rear shock there is a circular opening in the swingarm. Am I SOL on getting the socket out? I don't really care it fell in there, I'm just not sure if it will cause me any problems. I don't really want to take the whole swingarm off just to get a socket. Any suggestions on what to do?????
Wont hurt anything. You could tray and snake one of those extendable magnet pen things in there and try to pull it out. Shitty place I know, no room without ganking the shock.
1 - 8 of 8 Posts
