1 - 11 of 11 Posts
a simple hardware store fix, 2 bolts at about the total cost of 10 cents..
Where did the original bolts go?
Ok I'm confused, why were the no bolts in those holes? Does the 08 just not have those from the factory and I've just never noticed before?
Wow, one of those bolts, (on the right side) also holds the clamp that holds the stock cables for the servo motor. Someone on the Kawi assembly line needs drug tested. :spit:
On mine one was missing, I assume it rattled/vibrated out, as did a few other screws. The damn japs get some bolts Heeman tight and others are barely started it seems.
1 - 11 of 11 Posts
