1 - 6 of 6 Posts
Had a private track rental at SGMP this past Friday, I ran the bike out there.
The bike is bone stock other than being lowered in the rear with the front end strapped (compresses forks to keep them from unloading on launch) - just stuff to help it from wheeling the front tire so bad.
Best pass of the day was:
60': 1.995
1/8: 7.273 @ 109.65mph
1/4: 10.860 @ 134.31mph
I backed it up with a 10.972 @ 134.35 mph as well as a 10.998 @ 133.66mph.
The rest of the passes:
11.050
11.059
11.209
11.297
I've got another track day on the 18th - shooting for some 10.6s this time around - then maybe some low 10s after I gear it (-1 in the front).
I'm 305ish in gear.
Awesome!! Are you burning up the stock tires too or did you replace them already?
I'm on the original tires. 36xx miles on them and both are in need of replacement soon - probably 4000 or 4200 miles is all they have in them.
I never turned the tire over much less did a burn out or lower the tire pressure - its a stock wheel base bike and I have NO problem with traction.
I'm working on it - I need more seat time! :thumbsup:
good job man:thumbsup: your right just more seat time and it will come
1 - 6 of 6 Posts
