1 - 2 of 2 Posts
Well, here are the results of my dyno run with my "homemade" pipe.
If you didn't know already, I took the stock pipe, cut the weld on the pipe pulled out all the internals, and put a pipe through the center exactly like all the other aftermarket pipes.
This is with a PCIII with the Two Bros map for a bolt on muffler. I adjusted the low up 4 bars and the mid 2 bars and the high 1 bar.
Temp of the dyno room about 75 degrees or so.
Also, it was a huge pain in the but to do this because I had to take the tank and airbox off to get the clip on the spark plug wire. I think it is a little jumpy at the top because I put the clip around both wires, and didn't cut the tape off and put it around just the one wire.
I will take pics of the bike this weekend so you can see the pipe and bike.
It dynoed at 151.4 HP, with my pipe, stock mid pipe and PCIII.
Discussion Starter #2
The fuel : air line is nearly straight with the adjustments to the PCIII now, the blue 4th gear line goes pretty much straight up, so guess it can't be all bad!
1 - 2 of 2 Posts
