1 - 16 of 16 Posts
I have a Bmc race filter....how much real world difference does running without a filter make?? Does it make any more power?? E.T. drop ?? If so...how much 1, 2hp??? .10th ???
thanks in advance??
thanks in advance??
Well considering that a filter is designed to keep crap out of your engine, I'm guessing that initially you'll get a lil more power but after you suck in a bunch of dirt and bugs, you'll ruin your engine....
If you really want more power, just pour a bunch of sand in your intake and it'll bore and polish your cylinders.....:heyyou:
hmmmm.......i already have ported head, so ill skip the sand.
Anyway...for those folks that go no filter soley at the track(and PLENTY DO!!)any REAL feedback would be appreciated:thumbsup:
Maybe look over at pyschobike as there are more racers there. If you have the time to search, I remember when the ZX14 came out in 08 I believe Gadson did a test of it bone stock with and without the filter, so it'll at least give you an idea of what you're gaining.
got a post on their now.....thanks:thumbsup:
:heyyou:
All in good fun, though on a serious note,
I don't really do alot of racing {track day here and there when i can afford it} so I wasn't aware that people did this...must be a draggin thing cuz I would imagine that just riding around or even at track days, this would really fuck up your engine after a short time....But I don't really know that much about bikes in the grand scheme of things...
Maybe you could post your findings...???
Licensed Dist of HaterAde
seems like there would be some small gains BUT would the bike/map need to be redone to make up for the added air and not lean out the mixture? i know that runing open headers will pick up a few HP so the filter would have to make a difference. there was an article in SSB a couple months ago on the headers.
probably without.........
I believe Rickey Gadson ran his zx14 without filter and with pump 87......he must know something for that bike not sure on others though.
bloo
Works better with the 14's than the busa's ssb mag did a myth buster story and it added very little but after replacing my 10r filter with a race one, the air box must work well cause it needed to be changed (less than 900 miles)also a good story in this month's ssb about gas 87 vs 91/92, only a very sm change as well.
1 - 16 of 16 Posts
