1 - 4 of 4 Posts
All show and all go 10r
ok I thought I could find something but no luck. What are the pros and cons of the 2 as I'd like to pick up another set of fairings for track days?
I've done a little asking around about abs vs fiberglass, and it seems the main difference is that the abs will crack easier. But if its a trackday set up and you dont have to worry about potholes and such, the fiberglass should be fine. And quite a bit cheaper. Just my :2cents:
Go with fiberglass. Main advantage is that they are a lot easier to repair, anyone can do it.
Cheaper, lighter and easier to repair - fiberglass gets my vote for the track.
1 - 4 of 4 Posts
