1 - 5 of 5 Posts
hey guys watsup i tried searchin no results
When i shut my bike off (2005 ZX10r about 11k miles) but leave the fuel cut off switch on after a while (5min) the fi light turns on and i hear the bike clicking this is all when the bike is off just wanted tokno if any 1 can help thxs
welds like he has palsy
Don't know if my problem is similar to yours, but whenever I turned the bike on, and before I started it, I'd hear a clicking noise. It was the servo motor under the passenger seat. The one that opens the butterfly valves. I had to replace it.
i think that is the clickin cuz its definatly come from that are but it only happens when i leave the fiuel switch on and shut the bike off
bump .
Take off your rear seat so you can see the servo. Leave the fuel switch on and shut the bike off because that's when you said it happens. The servo should cycle back and forth smoothly, but you may see it move then click back repeatedly. That's what mine did and I replaced it with one that I bought from a member here.
Or just buy a full system!
1 - 5 of 5 Posts
