1 - 16 of 16 Posts
I just got a 08 ZX10. It was wrecked in the tail section. I am getting two FI codes 52, 54. Anyone have a list on what these codes are?
Service Code Problems
11 Main throttle sensor malfunction, wiring open or short
12 Inlet air pressure sensor malfunction, wiring open or short
13 Inlet air temperature sensor malfunction, wiring open or short
14 Water temperature sensor malfunction, wiring open or short
15 Atmospheric pressure sensor malfunction, wiring open or short
21 Crankshaft sensor malfunction, wiring open or short
23 Camshaft position sensor malfunction, wiring open or short
24 Speed sensor malfunction, wiring open or short
25 Gear position switch malfunction, wiring open or short
31 Vehicle-down sensor malfunction, wiring open or short
32 Subthrottle sensor malfunction, wiring open or short
33 Oxygen sensor #1 inactivation, wiring open or short (Equipped Models)
34 Exhaust butterfly valve actuator sensor malfunction, wiring open or short
35 Immobilizer amplifier malfunction (Equipped Models)
36 Blank Key detection (Equipped Models)
39 ECU communication error
46 Fuel pump relay malfunction, relay is stuck
51 Stick coil #1 malfunction, wiring open or short
52 Stick coil #2 malfunction, wiring open or short
53 Stick coil #3 malfunction, wiring open or short
54 Stick coil #4 malfunction, wiring open or short
56 Radiator fan relay malfunction, wiring open or short
62 Subthrottle valve actuator malfunction, wiring open or short
63 Exhaust butterfly valve actuator malfunction, wiring open or short
64 Air switching valve malfunction, wiring open or short
67 Oxygen sensor heater #1 and/or #2 malfunction, wiring open or short (Equipped
Models)
83 Oxygen sensor #2 inactivation, wiring open or short (Equipped Models)
strange things happen in a smash m8, could have stretched the wires/loosened the connecters, just gonna have to trace em all and find it, good luck
inappropriate
its possible the coils retracted away from thier plugs. Does it feel the bike is running on 2 cylinders?
yeah,it does seem to be running on two cylinders. I am going to pull the air box off and check them first.
inappropriate
right, and disconnect that harness and clean the connectors too while youre at it.
The bike has only 485 miles on it and it has never been out in the rain. So hopefully it's something small.
Discussion Starter #11
checked the conections, everything looks good. got the same voltage going to each coil. ohmed out each coil all the same. tried swapping coils still the same result.???????
trace the wires for those 2 coils through the harness and i bet you will find a section of pinched wires that are running to the ecm that mounts at the front of the tail section.
OMG Look at that squid!!
What he said! Prolly a pinched area of the harness or even damaged/ ripped wires.
are the pins pulled out of the connector? if they are and the lock tabs are just bent back you can re bend them to their original position of your lucky. if not you will have to epoxy them into the connector to seal them into it.
1 - 16 of 16 Posts
