1 - 8 of 8 Posts
Hey guys, I went for a short ride today and noticed my temp was above normal, not to hot just above normal. I'm sitting at a stop light when all of a sudden my water pump hose blows off. Still temp was not bad, I must not have tightened the clamp all the way. So I quickly shut it down hop off. After I get the hose back on ( no coolant with me to add) I make a bee line for home with one eye on the road and the other on my temp gage, temp starts to rise so I shut it down again and noticed the fan was not running. I checked the fuse and it was fine so my question is what could the problem be?
Discussion Starter #2
Think I got it. I un pluged the wires to the temp sensor and jumped them, the fan came on so I must have a bad sensor.
Well I got a new T state and the fan still will not kick on???????????? I know the fuse is good? What now? I'm lost...........:dontknow:
Only so many things it could be:idea:
My bad. Yes that is what I got. I drained some of the water out of the system and let it heat up. The fan never came on.
Wire a waterproof manual switch, helps alot when in traffic.
1 - 8 of 8 Posts
