1 - 3 of 3 Posts
Ok guys, after a cracked frame, piggy work from my mechanical and a dusted bolt my problems did not finished yet :eyecrazy:
After fix all this crap I noticed the idle and lower RPMs, below, 3000 the bike was failing, like injector fail.
After 3000 rpms seems OK, 2nd gear is better....
Another curious think is the start, after all rebuild is more harder to start the bike, even if is hot... Sometimes just touch the button and they start, sometimes I need to keep it pressed :dontknow:
I have a PCIII with zero map, and GiPro...
Anyone have some idea where to start looking to fix that?
unplug the PCIII and GiPro in case theyre affecting anything.
But since youre describing it like an injector failing type issue, take the PCIII off and see how it runs. If its fine, put it back make sure your PCIII is fully connected and everything is in right, with good contact and all. Sounds like it may just be a little loose of a wire
1 - 3 of 3 Posts
