1 - 5 of 5 Posts
so i gutted my cat and im installing A&R baffles but i also removed servo cables but does that leave valves open or closed ??
Gen2 Ripper
Removing the cables leaves the valve open.
Late Apex
how will that effect low end performance,and idle?
I have the baffles too. also have the cables removed and it will put a dent in your low end till you get a tune due to the back pressure being lower . I noticed a change. throttle isnt as snappy either . Maybe you should try it out before you totally remove the cables .. Just let em hang and ride it a couple days ..
1 - 5 of 5 Posts
