1 - 14 of 14 Posts
I have removed most of my exhaust and im getting ready to install my Delkevic exhaust. The new y-pipe does not have an attachment for the 2 cables that are on the stock y-pipe. I'm not sure what it is or it's function. Can someone help a bit?
The exhaust kit also came with exhaust sealant. Is sealant supposed to be applied generously on both sides of the gaskets/flanges?
Sorry for the silly questions but I wanna get it done right.
That is the exhaust servo under seat that cables run from, to your exhaust. Much like an egr or exhaust brake. Closes a flapper in exhaust to increase back pressure to engine for warm up, deaccel popping etc. take cables off and leave servo plugged in for no check engine lights.
Discussion Starter · #4 ·
Thanks man I got everything put together, let it hang, and turned the bike on. Nothing happened so I rode it as is lol!
Discussion Starter · #11 ·
Funny you say that because I got some new clamps in the mail today. I had a leak and I broke the screw trying to tighten it. I used some sealant and I'll see if it fixed it tomorrow. While I was down there I was going to take off passenger foot pegs and the heat shields but the rear brake resivor is connected to it.
Where am I supposed to connect it if I remove those pieces? The pic you put up doesn't even look like it has one
Get rid of those heat guards and show those good looking pipes.
This! View attachment 415906
Sent from my Moto G (5) Plus using Tapatalk
1 - 14 of 14 Posts
