1 - 16 of 16 Posts
Im putting my factory header back on with a slipon but not a fan of the ugly light brown section where the butterfly valve is. Has anyone hot coated theres black or even use a high heat paint? how hot does the pipe get in that lower location?
Custom Powder Coater
U should be fine with High temp. paint/powder coating, the headers are the hottest and ceramic would be the best choice there.
I was gonna powder coat my headers but a couple HD guys said it doesnt hold on theres i decied not to try it instead im looking @ purchasing a ceramic gun and trying that along w/ my powder coating on the side.
Right on! Ya i figured just a high temp. paint used for engines or bbq's would work lol. I just wanna paint the exposed part under the rear set so it doesnt look so ugly.
Thanks a bunch
Powder coating is usually baked on at 350-450 degrees F so that probably wouldn't work well with our bikes, it'd eventually wear off.
had mine ceramic coated and they have lasted over a year with no signs of flaking or color coming through. they actually clean up better and the bike feels a little peppier. all i did was shorten/gut my stock can and ceramic the pipes inside and out. found a hotrod shop in missouri that did them for next to nothing and has lots of colors. two weeks and they were back on the bike.
I got some high heat ceramic paint good to 1200 degrees F . Im gonna try that first and see how she holds up
correct but there is high temp that runs to 1200 degrees and is capable for most parts of the exahust ;mid pipe y-pipe,can/cans. Just not the headers
Interesting, I'd like to turn mine black on the bottom but we'll see...prolly jsut get a cat eliminator and leave the exhaust the way it is...but black coated exhaust would look tits...
Heres a 10 with powder coated exhaust
high temp paint should be fine
Jet-Hot ceramic coating is another option. Never tried it on titanium but I can't see why it wouldn't work. I have the regular silver color on other bikes and it has held up very well. They make it in black and other colors and also in a verson for ultra high temperature like turbo stuff.
I've tried the high temperature paint on headers and it doesn't last very long.
I painted mine with Hi Temp Exhaust paint and it started peeling after about 6mths.
I getting it done in ceramic soon.
Joe
What was the name and number of the shop used?
I f you sand it, It will turn to that bare brushed titanium look. I have sanded parts of mine and they look way better than the coating that came on it from the factory.
1 - 16 of 16 Posts
