Muzzy Or Brocks Megaphone????
  • Total voters
    11
1 - 5 of 5 Posts
Custom Powder Coater
So looking for a new exhaust since I want to put some OZ racing wheels on. I want to be able to see the rear wheel better.. So that means I have to let go the dual exhaust go and move to a single megaphone setup (if I could get a left side exhaust I would but haven't found one). I know it will be loud and I will lose some low end power (my biggest concern) but from my research I notice muzzy kinda fixed that, not 100% but better .. They used a stepped header so it's restricted at the head and then gets bigger ...
I don't know of anyone else that does this? I know Brocks doesn't and I loss an extreme amount of low end power on my ZX10 with the alien head.. This is what's keeping me away from brocks megaphone! However I like the looks of it.. Id give it 5 starts and muzzy 4.5 in looks.. Performance wise muzzy beats out brocks according to a magazine exhaust shootout (done a few years ago).
I also contacted austin racing they seem to think the Z1000 slipons will fit. But I'm not so sure..??
So my post is basically to see what u guys opinions are?
The Brocks is the only way to fly on the second generation. The exhaust on the second generation needs bigger primaries and the only real header that pulls big primaries for racing is Brocks. Ivan showed the Akra header made more HP in some places on his dyno, but they aren't winning many races. I have the Alienhead 2 on my 2013 ZX-14R. Torque on the low end isn't really an issue when you can melt the rear at 3000 rpm.
If you're referring to this shootout then it's apples to oranges:
http://www.superstreetbike.com/how-to/exhaust-systems-shootout-smoking-pipes
If they used a ZX-14 after 2008, then (IMHO) the results are kind of flawed as there was a cat in the stock header if I remember correctly. A lot of horsepower was freed up not by the actual pipe design, but just by getting rid of the cat.
The second gen (2012+) doesn't have a cat in the pipe (in the USA) and it actually flows pretty well. If you look at the Two Brothers website they show the slip ons making more peak power than their full system!
So....for a first gen the Muzzy is a really good deal for the dollar...especially if you can find a map for it. If you plan on a full dyno workup then the Brocks system may suddenly seem appealing because they supply you with a couple proven maps.
So....Brocks for Gen 2. Brocks OR Muzzy for gen 1.
Brocks Alien Head 2 all the way for a 14R:thumbsup:
The two brothers system is too small in diameter to make good power on the 14 r, the reason brocks makes 15-20 hp over stock is it is a 2 1/4 inch diameter exhaust, the two brothers is a 2"
2" exhausts are only good up until around 200 hp, Brock tested this and this is why he came up with the alien head 2 pipe for the 14 r.....it is also a 2 1/4 inch muffler core
1 - 5 of 5 Posts
