1 - 8 of 8 Posts
Exhaust Butterfly Valve Actuator in my 2005 ZX10R ???
Hi !
My Exhaust Butterfly Valve Actuator cables are quite loose...when I turn the power on,the actuator make movement back and forth..When starting the engine...the actuator is steady when idling...when increasing rpms.the actuator moves slightly at 2000 rpm...when the rpms goes up to 6000 rpm---there is no more movement...
Is it OK ????
I did not find any rpm numbers and figures from the service manual...How it should work ???
Banned
i think you have to adjust those periodically like a throttle cable ,clutch cable, ect...but i never have because mines had evo 2 since it was new:dontknow:
Hi Guys
Sorry to bump this old thread but does anybody know if the later exhaust actuators are backward compatible with the c1/c2 model
1 - 8 of 8 Posts
