1 - 5 of 5 Posts
Hi am trying to find a fault on my 07..I had good replies which has been helpful in the meantime is there anyway I can find my own error codes first ?before I bring to a dealer and get ripped of..had very bad experience the last time.
Matt
Once you read the codes using ^^
Check the number below. Your 07 won't nearly have all of them. The numbers it does have are still legit.
Discussion Starter · #4 ·
OK thanks much appreciated I will be looking into this later thanks for the info 👍
Matt
Just a heads up...Healtech-electronics.com make a OBD tool that allows you to check and clear codes on you ZX10R. It's very reasonable. I have not purchased one but I will. When I switched to LED headlights it threw a code because of the lower resistance....:>)))
1 - 5 of 5 Posts
