1 - 14 of 14 Posts
· Chairman of the Board
I think you will find a vast array of opinions on this one. I would stick with the factory recommended viscosity and use a 100% ester based synthetic if possible. If not, at least a high quality synthetic.
:popcorn:
· Premium Member
You need a good quality engine oil of the correct viscosity (see owner's manual) which meets the JASO MA standard. Any recent motorcycle-specific motor oil should meet that standard, but read the statements on the bottle.
There are a wide variety of choices. Any of them will get the job done.
I use 75w-90 gear oil. Cuz the gears are in the engine oil. Then I top it off with a quart of Lucas Oil Stabilizer. Cant even hear the engine run its so quiet.
But on a serious note, just about any good synthetic should be fine. 10w-40 I believe.
oh god, it's getting out of hand! Oil thread on the loose!
One of those will probably help.
1 - 14 of 14 Posts
