Here's a quick, raw list. I'll provide more details when I get time. Please PM me if you see something you want to know more about.
For prices, assuming the part is in VG condition, I'll charge about 40% of Ron Ayers' prices, plus shipping. http://fiche.ronayers.com/Index.cfm.../46/Year/2005/ModelID/3527/Model/Ninja_ZX-10R
Water pump
Computer
Headlight relay
Rectifier/regulator
Coils
Harnesses (engine related, not chassis/lights, etc.)
Clutch parts (basket, hub, new nut)
Oil cooler
Starter with all related parts/gears/cover
Generator
Oil pressure sensor
Throttle Body w/ harness
Crankshaft position sensor parts
Gear position sensor w/ sub harness
Kickstand switch
Pistons/rods
Crankshaft (needs minor work)
Front sprocket - stock and 16T
Sprocket cover (gen 1 and gen 2) with speed sensor
Engine cases (need work)
Fuel hose
Headlight relay?
Thermostat housing
Engine rain cover (rubber)
Timing chain and related parts
Oil pump
cam cover parts left over from block-off plate mod
Damaged head with some good parts (cam cover, valves, springs, etc.)
Damaged (repairable) oil pan with good parts (pick up, extension)
Exhaust servo motor (06-07)
Water pump
Computer
Headlight relay
Rectifier/regulator
Coils
Oil cooler
Generator
Oil pressure sensor
Kickstand switch
Pistons/rods
Fuel hose
Headlight relay?
Thermostat housing
Oil pump
