1 - 13 of 13 Posts
I have an 04 zx10r with about 14,000 miles on it. I have noticed the past few times that I have rode the bike there is the slightest bit of oil leaking out of the left side of the engine near the top of the engine. Anyone have a clue as to why this might be happening? I am taking it in for service here shortly to get the valves adjusted, change the spark plugs, and put a new chain and sprockets on her. (-1, +2). Has anyone had this happen just wondering if it is a common thing or if it is just me. Thanks so much for your help.
Postwhore with an 04
I agree, propably just your valve cover gasket. Replace it and you should be fine.
I agree, propably just your head gasket. Replace it and you should be fine, you could even get a thinner one :thumbsup:
Dont scare the dude saying a head gasket! Its the valve cover gasket and yes its common on our kawis.:mrgreen:
Haha your right my bad sorry OP, I'll go fix it before he sees it. Sorry my mind is stuck on modding lately
Thanks guys I appreciate your help. I figured that is what it was, but just wanted to see if anyone else had that same thing occur. I don't believe that it hurts anything but it just pisses me off.
It shouldn't hurt anything, just have them replace it when you get your bike serviced.
Any other ideas. I just had service done new race cam and springs with a little more done to the head. I am now on the second gasket, we just cant seem to get it to stop leaking. The bikes been apart bolts checked. I am thinking about changing the cover but thats 110. + shipping from Ron Ayers.com I need some help.:dontknow:
Premium Member
I would silicone the valve cover gasket down (dont use a lot mind you) to seal any imperfections in the valve cover or engine. I had to do that with my ZX-7, and it worked well, just make sure you don't use a lot of it as you dont want goo in your valve train or oil passages.
La Flama Blanca
Good luck, if it leaked once, well I would not be suprised if it leaked again. I have had a few different leaks pop up on my 04, it is quite frusterating, I really like to keep things tidy and clean.
Same here nice and clean. 36xxx miles and still running good just do not want an oil leak. Good reason to get another, if only i didnt have to repair the 636.
Stupid JenningsGP:helmet:
1 - 13 of 13 Posts
