1 - 7 of 7 Posts
Hi guys, have been encountering this problem while riding.
Engine will auto cut off while riding, and only at particular condition then it will cut off, temp around 85 degree, over uneven ground and i can only start the bike at neutral after it dies off.
Mod to my bike just an aftermarket exhaust.
Have anyone encounter with this?
can you do a video?
Gen2 Ripper
check the side stand switch. sounds like its going bad.
:+1: Cut the 2 wires going to the sidestand and splice them together. That will bypass the switch just make sure you remember to put your kick stand up before riding.
I second that
Yeah the sidestand switch lives in grime/chain lube and vibration. When they start to go bad they will cause intermittant cut outs.:wink:
1 - 7 of 7 Posts
