1 - 7 of 7 Posts
inappropriate
Im trying to wire my VEYPOR VR1 data unit through my bike. In order to connect the RPM sensor to the bike i need to wire it one of two ways, either wire tap it to the ignition coil or wire tap to the tachometer wire at the tachometer harness itself. questions; what method do you guys recommend and where do i find the proper wires?
Rent this space
Take a pulse signal from the ECU , I dont remember what color off hand, but any one of 4 ignition driver wires will do the job.
inappropriate
inappropriate
is that wire 7 from that chart i found?
inappropriate
i ran it along the #2 coil. the project was running late last night so i had to stop short of an ops check. ill keep you guys posted. thanks
1 - 7 of 7 Posts
