1 - 4 of 4 Posts
just picked up a used gen 4 couple of days ago and i know ecu flashes are very popular.
is there any easy and quick way to find out if i have a flashed ecu without opening up my bike to see any aftermarket labeling on the ecu itself?
thanks
Turn traction control off
Turn off bike.
Turn on bike and see if traction control is off or on.
If off than you have a flash if on than you probly don't (unless it's the one flash that resets traction control setting with cycling of engine
EXUP valve work? air pump working? both usually disabled with flash. what's it rev to? flashed bikes usually have 500rpm over-rev. what temp do fans come on? usually it's dropped to 95C or so with a flashed bike.
Turn off bike.
I'll give it a try, thanks!
Sent from my SM-G935T using Tapatalk
1 - 4 of 4 Posts
