You can use a jack between the rear tire and subframe or a basketball.. inflate and deflate..Does anyone know if you can swap the shock through the big hole in the swingarm?
I can get the top bolt ok.
I want to be able to swap to a softer setup for the road
Scout , I would never take any mechanical advice from you !ahahahahDo you have oem shock in the bike? If so, don't change it. Shock is set up for suspension not comfort although I ride a lot and never have comfort problem.
You're always busy, but in an interesting way, not the typical vendor hooked way.
i have a mupo shock with a 115 spring and only 10mm seat foam.Do you have oem shock in the bike? If so, don't change it. Shock is set up for suspension not comfort although I ride a lot and never have comfort problem.
nothing is more comical than you talking suspension! :grin2:Scout , I would never take any mechanical advice from you !ahahahah
Getting your suspension resprung to your weight with proper sag is essential to happy brappppp!:x
yes, but let me clarify. oem suspension is set up for flick and throttle. If soft shock, pegs will strike asphalt as MORE throttle is needed to lift the bike into engineering turning specs; so soft suspension is a no no with any super bike. The throttle, even just cracked, in the turn, keeps the oem suspension working; the REAR turns the bike, not the front; the front flick sets up the turn, not the rear; and some weight into the turn finishes the formula.I've seen homemade tools done before (like on my FZ09 for instance) for an easy shock removal. +1 to that if you want to swap shocks back and forth for an independent street/track set-up.
Also I have to agree with Scout though in a sense. If comfort is solely your goal, and you've got like 3" chicken strips, you can do whatever you want. If you plan to ride aggressively at ANY point then I would stick with OEM. The Frt and Rr suspension are designed to work together to output a certain ride frequency (in other words they work together to settle the bike when the suspension is acting). For a race bike, you want a ride frequency with VERY short wavelengths (aka a stiff suspension). Certain disruption to the ride frequency whether that be via poor compression damping, rebound, pre-load, etc. can result in a pogo effect. There's a reason suspension tuning is an actual service some dealers provide and it's not cheap because it's tedious. The last thing you want is to enter a corner hot and all the sudden the ass-end of the bike starts pogo-ing and dancing on you and then you wake up to find out you're the victim of a RNickeyMouse YouTube video lmao.
Never looked at semi active suspension like mechatronic from Ohlins?Every decent racer has a selection of springs to adjust the amount of movement for different tracks.
Im not a racer but the bumpy uk roads are nothing like the smooth uk tracks.
Its all about compramise with suspension.
I just need to try find easier way as im fed up with removing my tank and seat unit.
I will try soon and post results.
I can suspend the bike ok. Ive done it a few times with a jack but i have removed the tank so many times that the threads are getting worn so i was hoping i could find a simpler way to do it.Really no easy way about it because the swing arm has to be freely suspended off the ground. Never thought of the basketball trick with jacks stands, that would probably be the easiest. I went to home depot and bought a long threaded bolt that fit all the way through that massive swing arm pivot point and just suspended the rear of the bike from the garage rafters with two ratchet straps held in place with some nuts at the end. Thing wasn't going nowhere but requires access to your garage rafters.
Basketball?!?! Genius! I think I might finally be able to adjust my preload so I can stop pogoing, although I must say I've gotten used to it, and can handle it better, but yeah, still sucks!You can use a jack between the rear tire and subframe or a basketball.. inflate and deflate..
The best is a pair of Jack stands from Pit Bull that support the bike with the pegs.
