1 - 8 of 8 Posts
Getting ready to install. But I am confused as to the handlebar mounted switch.
Doesnt this automatically kill the fuel charge when the shift lever is raised?
What's the point of the bar mounted switch?
I can still upshift with clutch if I like, right?
Speed Freak
the bar mounted switch is for like racing rules for no quick shifter, basically you put pressure on the shifter and then press the button and it will shit info gear.....kinda like a last resort to havin a quick shifter.
you have the regular linear shifter?
The box says " shift rod pressure tension sensor/ linear travel sensor/Bar mounted switch/shift rod"
So that's a "yes" I think.
inappropriate
whats you take on the device after you installed it?
you can override it and shift whenever right?
We installed it, but it's not workinmg yet. Just havent had time to mess with it. Yes, just shifting like normal for now.
Did you need to buy the push rod A or did you make the stock shift rod work?
I have a new pushrod from DJ, but as I said, dont have things working yet.
This is not a slam on the shifter, the problem is me not working with it yet.
Okay but from what you can tell; is a new shift rod "neede" I just wonder because im about to buy my QS and wonder if I need to order a rod from DJ as well with it or save my $12
1 - 8 of 8 Posts
