1 - 2 of 2 Posts
Hey guys,
I need help, I've fitted a Power Commander 5 and quickshifter to my 2010 zx10r, for some reason, the little blue light on the Dynojet Quickshifter is only coming on when gear is being selected. Yet on my friends 11' zx6 and 11' gsxr600 it stays on constantly. What's wrong??? Or is that normal?
Thanks guys
Jamie
Does the quickshifter function properly? If it works correctly then don't sweat it. :)
If not, keep in mind that there are two different quickshifters: pull activation and push activation. Depending on how your pattern is set up you can use either.... but only one is going to work for a given set up.
1 - 2 of 2 Posts
