1 - 3 of 3 Posts
The Dynojet Quick Shifter Expansion Module permits the direct installation of Dynojet’s Quick Shifter system on PC-V equipped ZX10Rs. The system works by cutting off fuel flow to the upper injectors of your bike, which unloads the transmission as you apply pressure to the gear shift lever allowing fast, clutch-less upshifts at higher RPMs. With proper calibration, kill times are adjustable for individual gears with a simple computer interface. Just connect your lap top via USB cable for quick adjustments to suit your needs.
Available for most ZX10Rs with a PC-V already installed, call TJ at 866.931.6644 ext 817 to get this sent to you fast. Send email to FORUM at RIDERSDISCOUNT dot COM and please be sure to specify the model and year of your bike for accurate availability.
Instructions are included with each bike-specific QEM kit.
OEM-compatible wire harness makes for quick and easy installation.
If you already have a Dynojet Quick-Shift sensor, you’re all set, otherwise, we have these available for every PC-V compatible motorcycle.
1 - 3 of 3 Posts
