Unlock maximum potential of your PC-V equipped machine with a Secondary Fuel Module from Dynojet. The SFM, as it’s known colloquially, is a required component for anyone looking to add a Dynojet quick shifter and it’s an especially useful device for anyone that’s had a proper engine build completed, superstock or superbike – as it allows your dyno tuner to provide the most complete engine maps possible.
The device plugs into the Power Commander V on one end, and the other side pigtails are attached to your bike’s secondary fuel injectors. These are the ones that come on at full throttle. When used in conjunction with a quick shift kit from Dynojet, these are the injectors that are shut off momentarily when you shift gears, thereby unloading the transmission and allow you to snick into a higher gear.
And of course, anyone that’s got a serious engine build and a competent dyno technician, this unit is a must-have for maximum top-end power. If your tuner knows the game, a map for each gear can be built using this device, truly unleashing every bit of power your bike can make.
To help unlock the true tuning potential of your bike as well as enable quick shifter functionality, call TJ on 866.931.6644 ext. 817, send a note to [email protected], or just shoot us a PM and we’ll get back to you right away. Just be sure to let us know exactly what bike you’re riding and we’ll get back to you shortly.
