With the Multi-Function Hub from Power Commander you can integrate advanced features into your PC3 USB for the ultimate in power output and versatility. A map select function allows you to choose between two different maps on the fly with a handlebar mounted switch. The gear position sensor input allows you to integrate different fuel and timing adjustments for every gear for the best possible acceleration. For those of you that have a bike with a turbo installed, your Power Commander can be programmed to automatically increase fuel delivery with the included boost input. You may also connect the hub for output to a Dynojet LCD display for real time feedback on everything your Power Commander is doing.
Available for Power Commander III USB applications, call TJ at 866.931.6644 ext 817 to get this kit sent to you fast. You can also email us, send those to FORUM at RIDERSDISCOUNT dot COM with DJ HUB in the subject line and we’ll get back to you right away.
Two versions of the Multi-Function Hub kit are available: one which includes the map select switch only (shown) or the complete kit with harnesses for gear position, speed sensor, pressure input and two relay outputs.
The hub itself is small enough to mount just about anywhere.
The two-way switch includes hardware for mounting to any 7/8” diameter clip-on.
