1 - 8 of 8 Posts
I live in s.cal near palm springs I am wondering if anyone has a place they know of that has and tunes bikes on a dyno that they recommend.. Also wuts a typical 15k service consist of.. I have just under 10 so I might as well dothe 15k and tune it.. I have k&n filter, TBR exhaust no baffle.. Any suggestions?
Two San Diego shops have a Dynojet dyno and can tune your bike for $300. Both are good. Do you have a Power Commander?
Lee's Cycles - Service & tuning
Cycle Visions - tuning
15K mile service should be:
Valve clearance check/adjustment
New spark plugs
Throttle body sync
New Air filter (if needed)
Oil change (if needed)
Inspect the chain/sprockets (replace if needed)
Lube the clutch/throttle cables
Check brake fluid (replace if needed)
1 - 8 of 8 Posts
