1 - 10 of 10 Posts
Yep, that's the norm.
Let me see if I can guess what your next modification will be.
You may want to do a search on airbox modification!
So what were the dyno results? Hp and ft.lbs?
That's normal.....what is your HP.....Did you do your brakes yet, stabilizer?
These is what I saw that is why I was asking.
Make sure the PAIR is plugged up or they will map it overly rich to compensate. Any tuner experienced should know this off the bat, but I would put nothing past anyone who claims to be a "professional tuner" these days.
Well did you make sure it was plugged?
Even with it tuned properly the bike will still let out some pops with some of the more high flow exhausts. I have a full Akra and PC and it did not pop until the packing burned down some. Now it does some.
I just got my bike Dyno tunned and costum mapped it has PC3,BMC and full exhaust system.
Now when I'm riding and on high RPM's when I slow down it makes pop from the exhaust like its backfiring. Is that normal?
What was your HP?
1 - 10 of 10 Posts
