1 - 4 of 4 Posts
Ok, ready for this one? How is engine displacement figured out? Is it the volume of one cylinder w/ piston at dead bottom x #of cylinders in engine (in wich case we don't really have a 998cc bike)...or is it the total volume of all cylinders w/ the pistons at their given position at any point in the crank cycle (in wich case a 4 cylinder liter bike would have cylinders larger than 250cc each)...or am I completely off the mark?
Still here
(Bore X stroke of each) X number of Cyls.
998 divided by 4 = 249.5 cc volume each cylinder could hold at bottom dead center basically.
OKAY now you've got me thinking
76mm bore X 55stroke in that bore.
Has to be in the conversion to cubic centimeters- I hate math
You need to use the formula for the volume of a cylinder. For the example you gave, converting to centimeters, the diameter of the bore is 7.6 cm, the radius is half that, 3.8 cm, and the height is 5.5 cm. Therefore,
Hillbillie Mod
:shady: :idea: :mrgreen:
1 - 4 of 4 Posts
