Wiggle wiggle??? hair dryer to soften up???So I conducted a search but was not able to find anything on this topic. Does anyone have an easy way to reinstall the ducts? Items 14073 b & C
Install in frame first line up the bottom creases first and the sides and top fall into place when you wiggle it. Use your hand into the duct to push and grab the edge with thumb to pull. Push pull wiggle and it will fall into place again line up bottom first and work your way in a line up the sides and top. Once they are lined up put the airbox in no bolts yet and same thing line up the bottom first in the air box and work your way up the sides and top same way and can be persuaded into place with wiggling push pull and yea I haven't been successful without cursing and swearing ever.
I don't know of an easier way other than fighting with them and swearing at those damn things.
In all seriousness, maybe a little heat will soften them and make them easier to work with, other than that I twist and push those fuckers in there and somehow make it work every time lol.
I thought about this route in the past but didn't know how well the rubber would hold up to the grease, I doubt the grease has any ill effects on the rubber but I didn't wanna take that chance.Silicon grease wiped around the edges.
Or.... Dielectric grease, petroleum jelly, etc.
I also use Dry Silicon spray on fairing tabs etc.
Its okay, as long as you use Elbow Grease! :helmet:I thought about this route in the past but didn't know how well the rubber would hold up to the grease, I doubt the grease has any ill effects on the rubber but I didn't wanna take that chance.
I'm assuming you've tried the silicon/dielectric/petroleum? No issues with it like eating up the rubber or anything?
Yes, no issues.I'm assuming you've tried the silicon/dielectric/petroleum? No issues with it like eating up the rubber or anything?
LOL!!!Ballsack. Need more ballsack. And seriously, if this is tough, you might not wanna take the bike apart any further lol.
Edit - just so im slightly supportive - i use a trick for stuff like this, usually made out of rubber, like my grips for example. I keep a bottle of rubbing alcohol around for cleaning and things like this. Drip some inside the grips and they slide right on and ive never had trouble with em not sticking. It evaporates in seconds when its all over. Same with getting grips off as long as no glue is used. Cram some inside the grip and start twisting - off in seconds.
Thanks!Silicon grease wiped around the edges.
The thing I don't like about that is grease sticks around and catches dust and that turns into emery plus it can be a dirty shit show next time you have to get at it and can make it easier to pop out as well which can be good or bad depending I guess.I thought about this route in the past but didn't know how well the rubber would hold up to the grease, I doubt the grease has any ill effects on the rubber but I didn't wanna take that chance.
THATS WHAT I WANNA HEAR!!! MOAR SACK SOLVES EVERYTHING!! Just fyi ive had a couple drinks at this point! But yea, we can also help with riding motivation around here!LOL!!!
Taking the bike apart isn't the issue, it's putting it back together... She's been collecting dust for quite some time now, I almost sold it but decided to get her up and running again. Move to Texas killed my riding motivation. I'll use your slightly supportive suggestion and see how that goes at this point I don't think my ballsack can grow anymore...
If that doesn't work I'll bust out the Petroleum Jelly...
Thanks!
