1 - 20 of 35 Posts
Did you machine that? Looks nice!
What are the benefits of a dry sump???:dontknow:
Very intrested to know as that looks like a work of engineering art!
Looks very nice.
Three questions:
1) Is the stock main oil pump retained, unaltered?
2) What kind of oiling troubles were you having? Just wondering why the stock system didn't work.
3) That looks like a scavenge pump where the stock water pump was. Do you have an electric water pump for the cooling system?
Looks very nice.
Three questions:
with 450 plus hp u need a good oil system im sure it uses the stock pump with a 2 stage scavange pump
Well sure (every engine needs a good oil system), but all a dry sump does is move the oil supply somewhere else.
I'm guessing this is a drag bike and the stock pick up was getting uncovered under hard acceleration? In that case I can certainly understand why the dry sump helps.
Im not sure what his issues were but it is a drag bike that im pretty sure had a flat pan with moving pickup im sure he will chim in soon
Discussion Starter #16 (Edited)
With a wet sump, it cannot keep up with with 2 plus g's of acceleration. No matter what anyone says. Plus when you lean on a 1000 motor past 350 hp it gets very temperamental. We did oiling mods to the cases and the crank so a dry sump will top off the list. This motor should stay together for a little while. Keep in mind I make 500 hp with 30 lbs of boost:thumbsup:
I will probably freshen it up after 3 or 4 trips to the track:mrgreen:
Depending on what the oil pressure logs say
I am going to a electric water pump as well
It uses the stock supply pump and it uses a two stage scavenge pump. The system will have an oik supply tank that will be mounted in the swing arm. Once that is done I will post more shots. It also has a water to air intercooler that we are thinking about going to an air to air if it fits or using another median to cool with.
So pretty. Do you have a nice baffled oil tank? I used a dry sump on a turbo drag ZRX and it still ate up bearings until I baffled the hell out of the tank, and used 9 quarts of oil. No shit.
I'm going to PM my email, could you send some pics of your shift cylinder set up?
Dean
Discussion Starter #18
Its a Petterson tank. Hasn't come in yet. I know Seb and Keith as well as Dwayne and a few others run them without any issues.
Dean, I would be happy to send you all the info I have if you could tell me what a shift cylinder is...... :crackup:
My god, this is pretty awesome and I diddnt even realize it was available!!! My bike makes around 300 rwhp at the top end of the track and there have been more then a few times when the dummy light starts flashin at the top end of the track and I have a flat pan with a swivel pickup.
Discussion Starter #20
Thats why I went to a dry sump
1 - 20 of 35 Posts
