1 - 8 of 8 Posts
I took out my plates (fibers and steels) to replace them and notice 95% of them were dry, what cause this??? and what can i do to fix this problem???
dunno, but when i took mine apart i noticed the same thing. i resoaked the fibers and buffed the steels and put it all back together. im thinkin about running steel braided line from my oil pan to the clutch to see if i cant get the clutch to stay cooler and last longer. i know it wont work when the clutch is inguaged because oil that is getting sprayed into the clutch is just going to fling off; however at idle it should work. My only question is how much pressure is comming threw that line. So i might have to use some type of electric pump. But will soon find out.
Clutch on my 06 feels notchy or grabbing when taking off from a stop. It has about 500 miles and I thought by now it would have started to wear in a little. Friction plates probly need to be soaked and reinstalled after reading this post. ???
1 - 8 of 8 Posts
