1 - 14 of 14 Posts
I have a Gen 3 with 24,000 miles. Bazzaz ZFi, TRE, Block offs. And starting a few weeks ago I would start it up and it would be running on 3 cylinders and it would be throwing raw fuel out the pipe . And after a while it would run on all 4 cylinders. it keeps going back and forth. I pulled the plugs and it looked like the #1 plug was fouled so I replaced it and flushed my tank. Airfilter was clean so no worries there. It ran good for a while and then it dropped the #1 cyl again. I switched the #1 and #4 coil sticks to see if could have been the coil. It didnt do it again for 2 weeks but then it dropped the #1 cyl again. It seems to do it on start up more then any other time. And its intermittent So Im thinking my #1 injector might be stickin open when my fuel system primes. Any ideas?:dontknow:
Does not drive into smoke
If there is fuel in the exhaust, then the injector probably does work. I suspect the problem is somewhere else, especially since it did work for a while after you replaced the plug.
Im thinking of removing the injectors and ultrasonic cleaning them. I will also remove the Bazzaz at some point. I just want to do one thing at a time so I can try to pinpoint the problem with out throwing a ton of money at it.
thats a very smart and wise option to do, and removing the Bazzaz is the best option to follow that, since its really the only thing electrically non-stock dealing with fuel
+1 on removing the bazzaz first.. When I started having problems with my gen 3 dropping a cylinder a couple months back I disconnected the PCV and bam it was running sweet again:wink:
Boomer Sooner!
How do you know it was dropping a cylinder and only running 3? ( I'm just trying to learn as much as possible )
One header pipe cooler than others. Spray some water on the headers and see if it evaporates equally fast. Or you can use an infrared thermometer.
or the blistered hand favorite of touch it lol. Please dont do this!!
Might be a stator going out...
What year ZX do you have? I had massive problems with my Gen4. Finally found out it was the firmware in the Power Commander.
Speedy
1 - 14 of 14 Posts
