1 - 5 of 5 Posts
Hi, does anyone have an old display for a 2016 10r? I just need the back of one as all the mounting lugs disintegrated on mine. I've only changed it to the race kit a couple of times and always took care to pick up the existing threads, so I've no idea why this happened.
The threads are stripped in the plastic housing? If so, just put some epoxy in there and re-tap them. Cheap and good as new!
Or buy this one for the 4th gen and just use the back plate. It appears to be the same as far as I can tell. Nobody seems to offer a 5th gen model like yours so I'd compare the pictures carefully before you buy the 4th gen version here.
AVDB 2011-2015 ZX10R speedometer housing
Discussion Starter · #5 ·
Thanks, I've ordered one & I'll let you know if it's the same part. I'm hoping that the housing is the same, just different internals. (different part numbers 15/16).
1 - 5 of 5 Posts
