1 - 3 of 3 Posts
Yeah, they are 1156 bulbs. But they have an offset pin configuration. So they are harder to come by as most replacement bulbs are just the standard 1156, which won't work. If you can find the offset config, then great. If not, just get the standard 1156 (very cheap and common) and file off one of the pins. It will be a little loose in the housing but won't fall out. Never had an issue.
EDIT: The 1157 and 1156 are pretty much the same bulb except the 1156 is single filament and the 1157 is dual filament.
1 - 3 of 3 Posts
