I installed the following mods on my bike all at once and now I am having some problems:
Micron serpent headers (these are surely not the cause)
LevelOne Racing can (this is certainly not the cause)
Dynojet PCIII with appropriate map
Ignition module (currently doing nothing because the PC3 has the old firmware, but I called dynojet and they said this could NOT be causing the problems I am having)
GIPro gear indicator with ATRE
Ivans pair blockoff plates
Factory pro velocity stacks (don't think these are causing the problem)
UNI foam air filter (don't think this is causing the problem)
Now when the bike runs, if I rev it, it lets out a decent amount of black smoke and then cuts off when it revs back down. The FI light is on and these are the faults I have when I jump the diagnostic port:
11
Throttle sensor malfunction, wiring open or short
12
Inlet Air Pressure sensor malfunction, wiring open or short
32
Subthrottle sensor malfunction, wiring open or short
I REALLY don't think I left anything unplugged. I did read in a how-to that when you install the ivan's kit, some people put a jumper in the white plug that the pair electronics are removed from (but this was on the 05 636)--is this necessary? Could it be causing this? Ivan's instructions don't call for it. I called Ivan's and they said that their kit could not be causing these problems, but who knows.
Any help is greatly appreciated.
11
12
32
