1 - 10 of 10 Posts
Thought I would write a short review of the Diablo Rosso Corsa tire which I have been using for the last few months. I have been using it on my gen 1 zx10 which is used 50% on street and 50% on track. This is single compound front with a two compound 3 zone rear. After some use, you can clearly see the section where the compounds start and finish.
My first impression of the tire was the smooth ride it offered compared to the Metzeller M3's I had before it. It filtered out small bumps and irregularities on the road. If you are looking for a tire that gives dunlop like feedback, this is not for you. It is also a very neutral steering tire. For street use, I ran cold pressures of 34psi front and 38 psi rear.
At present, I have done 4 trackdays on it and the left side of the rear tire is down till the wear indicators whereas the center and the right side have plenty of tread left. The front tire has plenty of tread left on it and might last one more rear. I did 2 trackdays without warmers and 2 with warmers. I realized how sensitive these tires were to hot pressure and running the correct hot pressures made all the difference. I ran hot pressures of 34 psi front and rear as per pirelli's recommendations. Good starting point for cold pressures are 30-31 psi front and 29-30 psi rear for track use.
In terms of edge grip, these tires are pretty good. Almost like a DOT race tire.When coming out of corners, the tire initially grips pretty well when it is still leaned over on the softer compound. But at the time when it is transitioning over to the harder compound, it may break loose if you are too greedy with the throttle. In terms of hard braking, these tires are very good for a street based track tire. This was the only street tire that gave me the confidence to get my knee down on turn 1 at Eastern Creek Raceway (this is a very fast corner taken close to 200kmph).
In terms of wear rate, this tire is very impressive and does not show signs of abuse at the track. Overall, I am pretty happy with this tire and would strongly recommend this tire to those who are trackday regulars looking for some longevity without compromising too much grip. Good tire for a street/track bike. I have attached some pics of the tire with 4 trackdays and a total of 2000kms (street + track use).
Hope this was helpful.
Good writeup!
I've got a pair of those on my 636 and so far i'm loving them. Very sticky street tire, and i like the neutral steering. I'm using 32f 34r, any more than that and i feel the bumps too much, think the tire as a really hard carcass. Other than that, its a really great tire, miles better than the BT016 i had on that bike before.
Good writeup!
Its more of a stiffer side wall than a stiff carcass. Yes, after the BT016, you will find any tire hard. Try the dunlop gpa's - thats a really hard carcass, Pirellis feel soft after them.
Late Apex
Hahahaha And I have the Flip Side of that .. My tires have a soft carcass. I have the Continental Race Attacks. Soft Front and Med Rear .... Wont do that again .. LoL .. Front Tire started tearing after 3 laps ..Tearing is the wrinkles on the edges cause the tire didnt properly scrub ....
Has a squishy feel but you get used to it.. It is however hard to determine via feedback that your tires are on the edge of its limits.. FOR SURE ....
:dontknow:
:dontknow:
I have been wanting to try these tires on the track. How do you rate them?
Late Apex
Street - you will love them ... the feedback on uneven terrain is remarkable. I run a 32f/30r tire pressure ..
Track- save your money. You will not be impressed...however... if you are confident enough to run a soft carcass tire tear it up ... just go with medium/medium. The soft/medium does not work. The rear once warmed up pushes the front to its limits faster than it should
Late Apex
That's a perfect wear.... that tire scrubs clean as [email protected]#t..... either the tire or the rider transition in corners ....
All show and all go 10r
Don't forget just because a tire wears badly doesn't mean it's a bad tire. Tire pressure could be wrong, sag could be wrong, or suspension settings. You can also over work the tires too.
Looks like I might have to give the Contis a pass. Might the Supercorsas next.
Discussion Starter #10
The tire looks a bit more clean because it has been used on the road for about 200kms after the last trackday. I didnt quite understand what you meant by "either the tire or the rider transition in corners". Does the wear pattern show a problem with my riding style? Any input will be appreciated.:thumbsup:
1 - 10 of 10 Posts
