1 - 7 of 7 Posts
I did the KLEEN mod right after I got the bike as I had gutted the stock can and never had decel pop. Now that I have the M4 CF slip on installed on the bike I get decel pop after I let off or blip the throttle.
I did not use the block off plates, I just pulled all of the hoses and capped the ends of the airbox tube and the inlet tubes on the pumper valves.
Anyone else have this problem or notice it. My 636 did this also, but once I got the custom map on it it quit doing it. I wonder if that is what I need to do on the 10.
I already ahve the KLEEN blocked off and still ahve the pop. Big Daddy said he has them also and still has some decel pop also.
It maybe something I ahev to live with then.
If the KLEEN mod has been done and you're still experiencing popping, you may want to check for exhaust leaks and/or consider remapping.
No exhaust leaks, chekcked that after the install and after about 1000 miles on the system.
My old 636 did it too with the same mods. I am waiting on a PCIII and then it will be time for a custom map again.
1 - 7 of 7 Posts
