1 - 6 of 6 Posts
So i ordered a DDM Tuning Kit, installed it, and everything worked. The next day i turned on my bike and the low beam flickered on and right back off. The High beam still works. I was curious if anyone else had this problem. I have a 2009 zx10r.
When i called them they said I would need a wiring harness, i just thought it was odd that it worked perfectly for a day and then i go to ride again the next day and it doesnt work.
I assume you've already done this, but i would start checking all the plugs, then the power/ground wire going to the bulb. If you have a test light it may save you some time.
Might be a bad ballast. I bought a set and my low beam did that all the time. Ordered a new kit from starroters. The ballast looked like it was built alot better and I have never had a problem. The kits take alot of electricity to get warmed up. It would be safe to say that is why your highbeam works because the bike is already cranked and then you switch the switch on. Where as the low beam is coming on while the bike is starting. I had this same problem and the new ballast fixed it
Yea i checked all my fuses. I called in again earlier today and another guy from DDM said it might be a bad ballast... When i get home im going to switch them and see what happens. Just sucks i already hard wired in the high beam.... hope i dont have to pull that crap out just to test it.
Damn my DDM low beam just went out about an hour ago :( I checked the plugs and its still out, I guess this answers my question as well....
1 - 6 of 6 Posts
