1 - 3 of 3 Posts
anyone used an A/F data logger for their zx10? if so which one?
I'm looking at the WEGO IV but wasnt sure if there were other logger choices for tuning. thanks!
Certified SLOW
I have a WEGO III incoming here. Havn't hooked it up obviously since it isn't here. However, in my research I came to the conclusion that III would be better than IV, since the III is a sealed unit. The IV is NOT and will get screwed over if you get stuck in rain.
Certified SLOW
More information on my last statement taken from http://www.daytona-sensors.com/tech_wego.html
The third generation WEGO III series is packaged in an improved low profile housing. WEGO III units with display and data logging use an ultra-bright daylight readable blue LED display that is water-proof and include a built-in USB interface. The older WEGO II units had a red LCD display that was prone to moisture intrusion and used an RS-232 serial data interface.
The fourth generation WEGO IV series is packaged in an aluminum housing intended for under dash or dyno lab environments. WEGO IV units are not sealed.
1 - 3 of 3 Posts
