Hi there, newbie here, I'm going to attempt a tutorial on a budget rebuild of my micron pipes from my crash damaged (lowside) ZX10R. Not done this before, so be gentle if it makes no sense. Here goes......
Prior to removal of the pipes, loosen the small allen bolt under the tail exit pipe and the allen bolt that's inside the tailpipe.
https://www.zx-10r.net/forum/attachment.php?attachmentid=419655&thumb=1
https://www.zx-10r.net/forum/attachment.php?attachmentid=419653&thumb=1
Now remove, the pipe, it's held on by four allen bolts and a simple strap. I had to heat the bottom ones up, as they were well rusted from repeated hot/cold and of course gravity makes sure that that's where all the condensation gathers. Don't use oxyacetaline as this can quite easily go above the melting point of aluminium, I used a small hand held mixed gas burner. Get the pipe on the bench. Remove the 2 allen bolts that you loosened earlier and wiggle and pull the exit pipe until it comes out. Dont, pry it out, just keep wiggling and pulling.
https://www.zx-10r.net/forum/attachment.php?attachmentid=419657&thumb=1
Now get an 18" plastic ruler, or similar and slide it down the pipe, inbetween the wadding and the pipe, all the way round the pipe. This will loosen the wadding, so it comes out in 1 lump, rather than a big ball of fluff! It,s actually cellotaped together and its the tape that sticks to the inside of the outer pipe. The Micron badges are rivited on, so you'll have to work around them a bit.
https://www.zx-10r.net/forum/attachment.php?attachmentid=419659&thumb=1
Now you can pull from the other end and slide the entire baffle tube and wadding from the outer. Keep an eye on what you're doing, if you start to pull the tube out and the wadding stays put, then slide the ruler back down the side and double check that you've released it all the way down. If the tube comes out separately it'll cause you aggro, so make sure it comes out in 1 bit.
https://www.zx-10r.net/forum/attachment.php?attachmentid=419661&thumb=1
If you have the extra baffle tube fitted, you can choose now, whether it stays or goes. You need it in the UK to meet noise pollution levels and because we don't have any crime other than vehicle misdemeanor, the police will take an £80 interest. Don't know about other countries though.
https://www.zx-10r.net/forum/attachment.php?attachmentid=419663&thumb=1
You should now have an empty (damaged) tube.
https://www.zx-10r.net/forum/attachment.php?attachmentid=419665&thumb=1
If you want to retain your Micron badges, remove them now. Drilling them out from the outside is risky, so use a dremel and grind the rivits down from the inside.
https://www.zx-10r.net/forum/attachment.php?attachmentid=419667&thumb=1
These outers are made from 110mm x 0.5mm stainless tubing. Guess what, that's exactly the size that gas flue pipe is made from, so straight onto Ebay for me and £24 later I had secured a metre of pipe.
https://www.ebay.co.uk/itm/Stainles...var=462049968609&_trksid=p2057872.m2749.l2649
https://www.zx-10r.net/forum/attachment.php?attachmentid=419669&thumb=1
Measure your pipe and cut the new pipe to length. I taped the pipe and then drew round it with a sharpie, removed the tape, thus leaving a perfect line around the pipe. I used a 1mm cutting blade on my grinder as the chop saw is probably a bit aggressive for 0.5mm steel. Do a few practice cuts first, so you know what to expect when you cut for real, don't let £24 spent, rapidly become £48.
