Hi all, I’m new to the forum but have used is countless times to find solutions to my problems:) I can not find a topic about my problems tho. I got service code 23 so replaced the cam sensor. The old one read out of range on the residence on the multimeter. I put the new one in an the same code popped up before even trying to start. I trued starting to no success. I pulled the new sensor out an the resistance was correct at 425 but the little prong on the end of the sensor looks damaged, could this be another problem deeper down. Any help would be greatly appreciated. Thank you Chris
