1 - 4 of 4 Posts
Driven Racing D-Axis rearsets are built like a tank! That’s what we thought the first time we picked up a set. A nine-position base plate is included for most models, giving the user up to 24mm of adjustability up and behind the OEM footpeg position. This is further augmented by a D-Axis eccentric footpeg adjuster plate which covers an additional 12mm of adjustment over its 360° range of movement. Users should have no problems finding the perfect fit on their bikes! High-quality assembly hardware is used throughout which, when combined with the beefy brackets, should impart a high degree of crash durability to these rearsets. And, replacement parts are readily available directly from Driven Racing. Should your rearsets get beat up beyond use in a crash, just refer to the included schematic diagram (or Driven’s website) for helping finding the exact part(s) you need! These rearsets are designed to work in either standard or reverse shift pattern with no special parts required.
Available for all 2006-2011 Kawasaki ZX-10R motorcycles.
Driven Racing D-Axis Rearsets are not yet available on our website. To order, call Mike at 866.931.6644 ext 804. If you have any questions send us an email: FORUM at RIDERSDISCOUNT dot COM with ZX10R DRIVEN D-AXIS REARSETS in the subject line and we’ll get back to you right away.
Driven Racing D-Axis rearsets are built like a tank.
This simple eccentric footpeg adjuster allows the user to tailor the bike to a perfect riding position with ease.
Folding toe pegs are a standard feature on all D-Axis rearsets. These increase crash survivability over fixed toe pegs which have a tendency to bend or snap off in a crash.
Footpegs are hollowed-out on their lowers so they should break off instead of forcing the substantial footpeg brackets themselves to bend/break in the event of a fall.
As with everything from Driven Racing, the quality of finish machining is top notch.
1 - 4 of 4 Posts
